@tph479
Reply to tph479…
Reply Replies (3)
R
We highly recommend the timing covers. They are a complex casting, not easy to reproduce and machine.
V
I purchased a couple from Skip over the years. If Mark is doing them the the same level you can't go wrong. A cheap solution to a known problem
vintagerodshopAug 11, 2020I purchased a couple from Skip over the years. If Mark is doing them the the same level you can't go wrong. A cheap solution to a known problem
If you have a 12, you need one.
Reply to tph479…
