Nice work,
looks like the same as in my 1930 studebaker President.
would it fit a 668c delco dist.??
ken
Hi Ken
I have no idea, the shaft it fits is .625" if that helps. I will post the diameter of the contacts a little later today, just now running off for a few hours.
Lynn
It would be great to have some of the critical dimensions, it looks like it might replace NE 5033469 used in 33/34 Packard Eight and Super Eight, and in short supply. No offset between the two ends, exactly 180 degrees apart?
I took a few measurements this morning, these are all close and may not be exact but you should be able to see if this will work for you. If anyone has a rotor that is in short supply I would consider doing a run of them, maybe 8-10 minimum. It's a lot of work to get them to the finish line. All of the brass has to be milled to size, width and length, radius cut, spot faced for the tube, soldered etc. Then making the mold and the rest of the process.
