hdbob5454Apr 12, 2024
1940 chevy rear axle seals are leaking been a lot of years since I did one never on a car this old, do I just remove the cover on the rear end and remove a clip to slide them out?
Yes, after you take the spider gears out so you can slide the axles in slightly to get the clips out.
Try posting in AACA Technical. https://forums.aaca.org/forum/15-technical/ A majority of the people you would want to see your thread probably don't read the CCCA forum. I imagine that is why it has taken so long to get any responses. Good luck with the project.
