Post a photo. Original nos caps should be available for less than 250 dollars. Best guess is there is not a modern substitute. You would need to change the distributor, so staying stock will probably be less expensive.
Even better, please provide the Delco distributor number from the oval tag, 3 numbers + a letter, on the left side of the tag. On the right side of the tag is a serial number which is NOT important. I agree with Ed as to using the correct cap.
Dallas2, contact me at tsvanmeet@gmail.com or 402-359-5762 or 926-6909 cell. I have several of these caps and rotors.
Tom
Tom, Sent you an e-mail last nite requesting info. Thanks
Tom, Thanks for the reply---notified friend regarding availability and pricing.
The rotors with the tails on them are particularly nice as they allow for full movement of the spark advance/retard.
Post can be closed---Thanks to Tom, my friend has partisan order and we can now get to working on the 31 Study.
Thanks to all that responded.
