The "brush-off" wasn't meant as such, he posted the same question in the Packard forum area and that's where I happened to be when I answered it. In a nutshell, drop the headlight switch, the hand throttle sector gear if so equipped, remove the levers for the throttle and headlight controls, loosen the gland nut and push the concentric brass tubes for these controls upward such that they exit the steering column from the top, lifting the horn button. That that gives access to the steering wheel retaining nut.
