call 3M for tech service. you said that you know the top is vinyl. Are you gluing the glass to the top fabric or is there a seal in there? I suspect if it's to glass you will need a organo-silane + polyurethane type adhesive.
What is organo-silane + polyurethane type adhesive, and where can I get it?
I called 3M and they had no recommendation and were afraid to suggest anything, They are worriied about being sued if the window fell out. I told them there is a big market for something that works, They said they are thinking about it.
actually the market for individuals gluing their roof to rear window is tiny from 3M's commercial viewpoint. It sounds like their consumer tech line was not too good - try their industrial. the organosilane-PU is a guess based on the materials you want to bond and how encapsulated windows are made industrially (you don't have the temperature or pressure available). I think their industrial automotive office is in Livonia, MI. They should be able to recommend a current product.
DAVEAGAIN909,
If they gome up with even a wild suggestion, Please pass it on - preferably in a PM or E-mail me.
My 1970 Cadillac has the same problem --- I tried silicone with modest, but temporary success, but it is a thick layer to seal, and does not look attractive.
Thanks, and good luck,
