In addition to the paper filtering substance mentioned above, some filter designs from the 1930's use a cotten thread material as the filtering media. You can imagine the natural breakdown that would occur with that substance over the years, and the bad outcome that could result if the filter was eventually put into service (as noted by Owen_Dyneto above). John
