REGARDING BUICKS, PACKARDS, and speed trials.
Yeah - you "got" me on the Buick hyd. valve issue - been many years since I had a "in-line" Buick in my shop - must have been thinking of the later ones. Refresh my memory - I do not recall when Buick went to hyd. valve lifters.
Are you aware that the "large" series Buick straight eight (320 cu in.) was so good it was used in some busses ? ( I am curious to know if those Buicks that went into busses had "poured babbit" or "insert" type rod bearings.) The "356" Packard was so good it worked out well in boats, where
Yeah..I agree...so much "hot air" floating around the auto enthusiast circuit. And the cars dont help, either. Many cars of that era, including my dad's '36 Packard 120's speedometer, went up to 120 mph - on a car that would be hard put to make 80 mph !
Hope you can make it to the GILMORE CCCA Packard meet at the end of the month. Of course we will be having fun making up "tall ones"...but, amongst the story-telling, you might be able to find the info. you are looking for.
For those of you reading our "posts", be sure you understand this up-coming week-end Packard meet at the GILMORE CCCA Museum (May 30-June1) is NOT just for what our fellow chatter calls the "correct pin-stripe and radiator hose" set. It isnt even restricted to CCCA approved "classic". If you have a PACKARD, this is going to be the meet to attend ! See elsewhere in this "site" for details.
I agree with you about the "bottom line". And we all know there are "horses"..and there are "horses". Assuming simliar compression ratios, it all boils down to how much air-fuel mixture you can burn. My "hunch" is the much larger displacement Packard had a bit more raw "guts" than the Buick, and, given its much higher final drive ratio, would "eat" the Buick for breakfast. Before you Buick fans get restless, let me again assure you I love em both - just noting the technical differences. No question that the much lighter Buick would out-accellerate the Packard - at least up to where wind resistance would factor in with the Packard's greater power.
I suspect we all agree that "factory" horse-power claims...were just that.."claims". There is quite a lively discussion in the CCCA magazine this issue about that the Duesenberg really was all about. In the late 1960's, a friend of mine had acces to a dyno. We put on the latest Plymouth factory hot rod..a coupe...it was bright red...had a decal of a wood-pecker, if I recall. It was advertised as having some outrageous horse-power figure - cant no recall what it was. My Packard Twelve was advertised as having 175 h.p. You guessed it - the rear wheel "shaft-axle" horse-power of the "humongeous horsepower Plymouth" was 128. The Packard....126 ! Sic transit gloria!
See you at the Packard meet !
