Harold, you might try Hampton Coach. They do mostly 1930's GM interiors but they may have something close. A longshot is Bill Hirsch or Restoration Specialty, all of which should have web sites. Good Luck, Todd
M
· Mar 19, 2002
have you tried the drapery section of a fabric store
M
· Apr 23, 2002
"footman loops" are C shaped metal brackets that were screwed to the door of a pre WWII car, through these a piece of leather or fabric was "looped" and then both ends were screwed to the body., thus the strap through the loop prevented the door from traveling out to far when opened and hitting the fender or springing the hinge. What you want to find are assist straps. These 'assist' you out of the rear seat as a hand hold to pull on.
